My '95 started stumbling last weekend. I figured the fuel filter was dirty. it got progressively worse.
Replaced the fuel filter today and it didn't help so I went through the list.
1) checked codes. There are none.
2) tried known good PMD.
3) checked and cleaned all grounds,
4) changed OPS.
My fuel pressure gauge reads between 4-5 psi @ idle which it has since I installed the gauge six months ago.
When I jumper the relay the lift runs and fills the FFM.
It idles fine, no unusual smoke. It's been running great up till now.
I guess my next step would to replace the lift pump. Does any body have the AC Delco # for the good stock pump?
My gut feeling is it's not the LP. If the FFM was full of fuel at idle wouldn't it run smooth for a while until the FFM ran low on fuel because the LP wasn't keeping up?
The injection pump only has 50k miles on a new standyne.
Any ideas?
4) changed OPS.
Any ideas?
