Bobbyjeffers
Hello new here. I'm in need of help I have a 95 Chevy 6.5 diesel. I'm having lots of trouble with any help thank you. Ok heres the problem. The truck didn't want to start cranks great I put a pick up pump in it and fuel relay. Got fuel to ip still no start up changed control mod . Then found I had no fuel to injectors. Was told ip was bad. So put a used ip on off a running engine. Still no start checked all fuses I do have power to ECM on ip power on pink wire no others. And I think there's got to get power to the wire running to rear of pump by the injector lines of I fun a power wire to it the truck will fire right up. BUT the truck runs wide open and will not go to idle it runs up to 4000 rpm in about 5sec and then I shut it down in fear of it going boom lol. I really need help only thing I have to drive
