Would start and run fine last fall, needs cooling issue fixed so let set all winter. when weather got warmer this spring tried to start before getting back to cooling problem. Engine cranks ok but will not fire and has loud clicking sound while turniing over. Lift pump is working ok (wired direct) plenty of fuel to filter which i just replaced and flows good from T valve when opened. Have 12v to 3 connections on IP, pulled return line off pump and fuel is present but does not squirt or spray when cranked. Dash lights all come on, glow plugs etc. I planned on getting the engine to start and then having someone else do the cooling work as I have limited physical ability thanks to arthritus but I need to get this issue figured out first. Any help pointing me in the right direction would be appreciated.
Thanks, Mike
Thanks, Mike
