midniteplowboyy
Recruit
I'm running my 6.5 tach off a 180amp Delco 22si alternator on my cummins, the tricky part is finding the right pulley. IIRC, I used a 54mm alternator pulley with the 94 5.9 cummins crank pulley, you might want to double check my math.
Your dodge/cummins or any common alternator should work, you just need the a/c signal off of one of the stator legs, I believe this is the "R" terminal on some internal regulated alternators. You or your alternator shop may have to add a post/wire if yours doesn't already.
