Im sure this problem is covered in some forum somewhere but I have read and looked for 2 hours now. Maybe someone can help.
93 6.5 TD 130000 miles. Truck has been running fine. I went to Atlanta last week and did a little hauling and on the way home that night I stopped and refueled. Toped radiator checked oil etc. Once I got back on the hwy (empty), I noticed that it was running warmer than usual. it normalt ran 180-190 and it was running 210. I thought maybe bad fuel or something but it slowly getting worse. I went on a short trip empty and it ran 230 most of the way. I noticed that if I stayed around 60 mph it would cool down to 210. If I drive it hard it jumps to 230. Ive noticed that the gauge will jump back and forth 30 degrees in a flash and back up. I replaced the thermostat and it made no diffrence. ive noticed that sometimes it doesnt seem to have alot of power. When I take off from a stop it hesitates then kicks enough to have to let off the pedal a little. I have also noticed the oil pressure gauge will spike every now and then from 40 pounds to 60 and back down. I guess I need to know if the WG or something is open a little does it cause it to get warmer? It also will surge when first cranking up. The exhaust is straight 4" Thanks for your help! Scott
