88gmctruck
02GMCtruck
So, here is the deal; I'm converting all 8 of the forward lighting on my 88 to HIDs. I know, it's a bit overkill but I like having lots of light. The goal is to have all HID forward lighting, installed into non-projector housings. The hardest part of this will be having minimal glare and a defined cutoff line, similar to a projector. This is only possible with the proper optics and shielding.
Part of this plan was set in motion when I converted my headlights to the Bosch E-code headlights for export models (more information here: http://www.thetruckstop.us/forum/showthread.php?p=240731#post240731). They use an H4 bulbs and have a much more controlled pattern to them over anything I've seen for a GMT400 light. They actually have an appropriate cutoff line due to the E-code compliance and the optical qualities of the H4 bulb. Plus they are H4, so the lows actually act as a high beam as well. I've done alot of research on using shielded H4 based HIDs and have seen very good results with very minimal glare.
All the lights are 4,300k color. I picked up the H4 Bi-Xenon and the H3's from James (Mad Maxx). The HIDs I got from him were similar to the other kits I've bought on ebay; however I'm glad to have bought them from a fellow member. He was definitely a pleasure to buy from, and shipped them out quickly. Thanks James.
The plan:
- Lows: Bosch H4 ECE low housing, shielded H4 Bi-xenon HID
- Highs: Bosch H4 ECE high housing, modified H4 unshielded HID
- Fogs: KC LX2 Wide beam foglights, modified reflector, possible custom sheild, H3 HID
- Spotlights: Eurolights H7 Conversion reflector, clear lenses from GE sealed spotlight, H7 HID
- Completely re-wire the lighting system in the truck, and mount all the ballasts in a hidden location
Fogs
So, I got a little anxious and did some work before taking pictures. I already have the KC fogs done. I separated the lense from the reflector and painted the bottom high-temp black. This limits the light that can shine upward and cause glare to oncoming drivers. Few picts with them sealed and the HID installed.
Spots
Now, onto something bigger. Currently, I have 50w, 100,000 candlepower spotlamps in my bumper. They are sealed beam made by GE. They are unfortunately all glass and trying to retrofit an HID in there accurately isn't going to work so well. Instead, I'm essentially building a light from my old Eurolight H7 conversion lowbeams with different lenses.
The Eurolight lowbeams, while better than the stock sealed beam lights, are utter garbage compared to my bosch lights. Since the lenses are what focused the lights, the reflector simply directs it through the lense. After comparing the curvature of the eurolight bucket to my sealed spotlights, it looked like these would work just fine for the task. So, I pried off the cut lense and cleaned the reflector. The clear lenses are identical to my GE sealed beam spots, however these were never epoxied on a reflector; they were used as a shield for the fog lights on my dad's Kenworth T800 ironically..... The best part is the lights are going to say "Sealed Beam Halogen" and are DOT/SAE approved. :lol:
After getting them together, I tested one out. They are obviously brighter than the spots they are replacing, but the reflectors are just a little different in a good way; they are even more of a pencil beam spotlight than before. Just with my initial test, I was able to light up houses like daylight a few streets down.
Highs
And getting started on the Highbeams. H4 halogen bulbs use two filaments, once shielded (lowbeam) and one unshielded (highbeam) in different positions. Since most HIDs aren't used as highbeams, they are made to reflect the lowbeam position. So, I'm modifying the focal length of the HID to mimic that position. I haven't quite gotten there yet, but on the left you can see the standard H4 HID (with shield and halogen highbeam) compared to the modified position on the right. There will be more work with this later.
Lows
Out of the other 3 sets of lights, these will be the easiest to install. They are H4 Bi-Xenon HIDs with shields. the shields mimic the standard H4 very well, so they shouldn't need much modification, if any.
More progress will come later this week and weekend. the lows and highs are still in the truck so they are a little more on hold since i'm still driving it. I should be taking the truck apart, wiring and installing everything Saturday and further tweaking after i can get them out on the road instead of just in the driveway.
The plan:
Fogs
Spots
Highs
Lows
