Acesneights1
I had his balanced system. Truck still ran hot towing.
I think there is no reason to go 180's.... The 'head start' theory doesn't do much for me.
My opinion is to limit the temperature swings as little as possible. Its also proven that the hotter you run, the more efficient the engine is (economy, mpg).
When the engine is working, having it fluctuate between 190 and 205 is ideal IMO. 205 being when fan engages. That is how I have my rig set up now and I feel really comfortable with it.
Having it 'bounce' between 180 and 205 is just that much more for the metal to expand and contract consistantly. Once you are working the engine to the point where it will break the T-Stats open, and higher, the odds are its not going to stop on its own until you either back off the load, or the clutch kicks in, so why fluctuate the temperatures when the 190's are factory.
I refer to them as 190, as thats what my scanner shows my ECT at idle, and after fan clutch kicks in.
Having a mix, will make it run at the lower T-stat setting, until temps rise enough to open the other, but I don't think the extra flow of the 2nd will make all that much difference, and it will still keep heating up until load backs off or fan kicks in. So it would be basically running at that of the 180 temps.
With Heath diesel's recent price increase from the $5xx.00's I would like to know the difference again from a factory 2000 year system as Turbine Doc says there is.
Aka:
"SUPER-COOL" Cooling System Upgrade Single Stat - '92-'96 Single-Thermostat System trucks '92-'96
Our Low Price: Only $629.00 :rippedhand:
I can get a SD clutch, HO pump, and have Ron Davis build me a thicker radiator for this amount of cash.:nonod:
I wouldn't worry so much about your water pump unless it is not working and needs to be replaced.
Most times you get what you pay for.....Heaths rep pretty much speaks for itself.
go to Haydens website.You can look up the fan clutch for the 6.5 99+ and it gives all that info.
3500GMC, The 'electric' part of clutch does two things.....crop..... So you are a pioneer in this effort, but it will be cost prohibitive.
Did just that. '00 6.5 WP pilot is listed as M36 x 2.0... And the fan bolt circle is 3.81" Shuks darn it.
Now there's a challenge! Hmmm. I guess first it has to fit a 6.5 WP, huh? It may still be do-able. I like the idea of total fan control. The clutch pictured was a freebie.
