Well I've sold 100-150 of these over the years and not a single complaint, and where do you see a double joint ? Both ends are single joint ...
You have a joint at each end. The 95-02 shaft has a joint only at the steering box and a solid connection in the middle. Go back to page 1, 1st picture, and look at the top shaft. That is a 95-02 shaft. Your shaft with a joint at each end, or as I called it double joints installed in a 95-02 gmt400 is adding a joint in the middle unsupported(3 joints, 2 shafts, and only supported on either end. This setup has almost killed people as a few put the borgeson shaft into 95+ trucks. Under hard steering that boot that holds the upper shaft up breaks, abd the shafts drop down binding up. Somebody on gmt400 learned this one the hard way when he wrecked his truck. It works until that boot breaks from the stress.Well I've sold 100-150 of these over the years and not a single complaint, and where do you see a double joint ? Both ends are single joint ...
Do u have one that fit a 97With a double joint it's an accident waiting to happen. 88-94 used a double joint shaft, 95-02 was only a single joint on the lower, and another joint on the upper.
I built mine using my stock shaft and the lower of an XJ shaft. That was why I made this thread was to show how to build an upgraded shaft for a 95-02 because nobody else was building one. The current available shafts were for the non airbag equipped trucks. When they went to an airbag, they completely changed the column and steering shafts.Do u have one that fit a 97
I finally had time to try the 4713943 and it will not work on my 99 Burb it's 90 degrees off.Yes, or CROWN 4713943.
My rag-joint lower steering shaft unit slides into the intermediate shaft and fastens there w/bolt and band type bracket around shaft.I offer the lower shaft by it's self, direct replacement.
OK, how much we talking shipped to 34442Yes , you pull your lower shaft out and slide mine in. I designed it using a 99 lower & mid shaft.
OK, PM me your paypal so we can do the deal.175.00 shipped
Also check your wed site link from thetruckstop "there is a issue" confirmed via a few different devices on my end...........175.00 shipped
Web site is gone, don't need it, word of mouth works better...Also check your wed site link from thetruckstop "there is a issue" confirmed via a few different devices on my end...........
