chevyCowboy
if its centerd in the bolt hole you can use the full toruge inserts. the cut off is as long as it is with in the outer edge of the bolt hole it will work
From post #5 on the tread linked above...according to my GM book on the DB2 6.5s if the cold advance is off it'll smoke white when cold. I highly doubt that it'd be that much smoke, but it could be part of it. When my IP was bad on my blazer it billowed white smoke like that on a cold start and skipped like crazy. The engine also shook like crazy. Are you sure the IP is good?
The video of the bad engine 'jumping' did not run very long. Is this one at least smooth and smokey?
