Crankme69
Mind blower performance is Snake Oil BS
So I finally got my new PMD and installed it last night. I will now go through my fuel system further by doing a OPS relay mod. and measuring my lift pump output/if any. And change my fuel filter.
I like this fuel vac switch idea, where did you mount the switches?
isn't their a monitoring device in the fuel manager? or does that only check for H2O in fuel?
Have any of you guys used these $35 in-line performance chips they sell on e-bay? E-bay seems to be littered with them and judging from the add their the best thing since sliced bread. Just wondering if anyone has had good luck with them or if its a waste of time. they seem to be called "mind blowers" On that topic does anyone recommend something of that nature for performance gain, edge, bully dog, etc.?
I found a bigger heat sink laying around and I decided bigger is always better right?
so I used that for my PMD, and mounted it behind the L-plate. let me know what you think,
What about putting an eletronic fuel pres. sensor pre and post FM? could you then toggle your reading between one display? or is this a stupid waste of time?
Why do you (great white) think you need another fuel heater pre FM?
Why do you use regular fuel pressure gauge if you have all those trick digital readouts in you cab could you hook up to that?
have you guys seen the Fuel Pressure Tap from PMD cable? what do you think about Hi-jacking the FM cap?
IIRC it's prefilter
