Trucker2k16
Hey fellas can anyone help me with the ring gap on a 6.5l or should i throw gapless rings in it and call it love? Would it be .004x4.055 the get the gap or .005x4.055 i know 7 and 8 run a tad hotter thanks
Stock bore sizeIs your engine standard or punched oversize?
Clarification of Total Seal "Gapless Rings".
Pictures: (This is a set from Leroydiesel.com in an Engine Tech box).
1992 6.5TD Rescue
I put a grand total of 4 miles on it fogging mosquito's since I "rescued" it. They couldn't get it to start anymore.www.thetruckstop.us
Results over years in my engine. Ring set direct from Total Seal:
Total Seal Gapless rings?
Any comments about using a gapless ring set in a turbo 6.5? (Yes my 6.2 turbo hybrid needs a ring set.) Curious about power, MPG, blowby vs. standard gap rings. Will be used for towing... Do they have a 1st/top ring gapless set vs. the 2nd middle gapless ring? I would be concerned about...www.thetruckstop.us
You can send your second ring in for a cost to be made into gapless. Or buy a set from Total Seal. Note other vendors here market generic rings sent in to be made gapless by Total Seal as noted above.
Yea thats whats messing with me all the old rings was all different sizes ive seen that 1-6. Are same and 7-8 are different im just confused and had to stop the rebuild for the moment.The ring manufacture has their own specs normally .... True Total Seal complete sets are different than others, and each ring has a different gap as well...
Harley cylinder jugs requires honing plates top and bottom before boring the jugs, honing to size and fitting the pistons.If I'm building it zero... but I use a honing plate....
6.5 GM/Detroit Diesel Honing Plate; Cast Iron [GM-6.5DD-R] : HoningPlates.com by BHJ Products , Honing Plates and Cylinder Head Torque Plates
HoningPlates.com by BHJ Products 6.5 GM/Detroit Diesel Honing Plate; Cast Iron [GM-6.5DD-R] - Fits GM/Detroit Diesel 6.5L Diesel V8 4.125 Bore In Plate R Model plate for use with stock-length head bolts, or studs Includes necessary hardware, wood storage box and instruction sheet Cast Iron...honingplates.com
