ak diesel driver
6.5 driver
Sure it wasn't a vacuum?
I'm within 45 minutes of him if he needs to unload the Tahoe. I call first dibsIf you get the thing running I'll buy it for $600
Sound like a nice one.
I would rig up a temp fuel supply using a 5 gallon can and LP. Plumb that to the FFM and see what you get. I ran veggie in mine and over time it plaqued (sp?) up the hard line from Lp to FFM. Had to blow it out.
Depends on where and when the diesel was purchased and the ambient temperature when the Yukon quit running.The veggie kit thats installed hasn't been used for a couple of years..all the problems occurred while running on diesel... I never got around to connecting the wiring back up...would i still setup an alternative fuel source to test if the sock is clogged...also i noticed when i removed the cap the was a hiss of air coming out ....oh after i did the lift pump test on the truck i went to replace my lift pump and the gas tank side let out alot of air...???
A delphi automotive one rated at 35gphWhat fuel pump did you put on btw?
