Edzzed
1 to 4 seconds is forever.
That is nuts, they put us on the rollers and simulate driving, I never heard him gun the engine when mine was tested
1 to 4 seconds is forever. I don't have to take any test by me but if I did and some idiot told me I had to stand on my unloaded throttle and run the risk of a rod through the block, I do believe I would be departing in a hurry with their info in hand to provide to the local authorities and start the extreme protest/appeal process...:mad2: NFW do I do that unless I'm on rollers.
Tom, you ever get your 4" exh. installed?
Hi Leo I, m taking that as a gentle reminder to do first things first (loL).
Welp, it passed this morning.
Sunday I changed the oil, fuel and air filters. I pumped most of the 10 gallons I put in the truck out into a can, leaving a few gallons to drive to the nearest bio station (a good 25 miles) away. I filled up with B75 (highest available this time of year) and drove it while and tested.
Our testing is not designed to, both in function and by our state administrative code, designed to hold the throttle at the governor. and excerpt from it "The snap-acceleration test cycle consists of moving the accelerator pedal from normal idle as rapidly as possible to the full power position, then fully releasing the throttle so the engine returns to idle." http://apps.leg.wa.gov/WAC/default.aspx?cite=173-422-075
The problem, I now realized after the idiot tech tried to get me to hold it, is that their system for whatever reason cannot read the RPMs on my truck very well. At idle it's all over the place; as low as 100, as high as 1,400, all while not touching the idle. First snap test the computer never sees the idle, and it's gets all angry. The tech gets a manager who promptly overrides the tach signal and the test was conducted manually. Passed at 34%. I'm sure it would have passed lower had there not been about 8 gallons of #2/powerservice/2-cycle in my tank.
I also called and talked to the testing company's regional manager. He said their test is designed to NOT hold the throttle down on the governor, and the first tech was entirely wrong.
Dave
Glad to hear that the truck passed. Have not had anyone say that they didn't pass the emissions test with the ATT. I am really interested in anything that was done if you would like to call me and fill me in on the details. Been MIA because of work and a few other things, so will be spotty posting but will try to make it at least once a week. Anyone that has questions can always call. I return all calls.
Dennis
