buddy
Active Member
There are the little screens inside the IP fuel inlet fitting, the lower half of it. there is one large screen around the whole thing and then on the very tip. Old fuel with some bugs could have clogged them up. And I assume youve already checked for fuel pressure at the inlet while cranking. Checking at the drain hose is pre filter and "last ditch" screen inside the fuel filter manager, either could be clogged.
Did the PO use bio diesel or veggie oil? Could be contaminated, you should take a sample and see what it looks like in a glass jar. See what kind of crud might settle at the bottom. The OS might get a film over it and make matters worse, but sounds like its picking up the timing, better so when the CPS is unplugged.
I am hoping you do get codes with the sensors unplugged that can tell you if the other one is working. So its good to verify you got the CPS code when its unplugged and you get the OS codes when its unplugged.
