Idk about the stock design K&N filter for the pickups- but I ran them on multiple other applications like my 95 Hummer.
I grew up in the Vegas area desert on dirtbikes, jeeps and pickups that go offroad a LOT. We learned to use 20%-30% more oil than K&N recommends - was taught this by one of their engineers at a sema show way back for super dusty environments.
I put 46,000 miles on my original 6.5 when the cylinder crack destroyed the engine. Replaced it with a 6.5 optimizer in 2004, and tacked on 70,000 miles with the same K&N filter since then. A glow plug broke and destroyed a piston, so I have it torn down now for that. I think I posted pics of the cylinder walls here of it - the crosshatch marks are noticeable still, but not a single vertical mark was there.
Oil analysis:
Levels of silicon and aluminum, the basic components of dirt, are clear indicators of an air intake filtration leak letting dirt into the combustion chamber. High levels of chromium suggest that the resulting abrasion is wearing chrome off the piston rings.
All 3 of mine were always crazy low except for the first break in reading of chromium when the rings were seating with the new engine.
There are better air filters available. If I were to get a long term filter now it would be a dry one. Not that I give up on, or think K&N is that bad, but there are other options as good now. If you are after performance, and don’t mind the extra time of oiling- then it is fine imo.
Many people won’t do oil analysis and monitor a filter minder or other similar vacuum gauge for these issues. If that is your case- avoid K&N.
I am actually kinda sad because how I am building my engine now,my factory set up wont flow enough air without restrictions to frequently. Gm6 turbo and turned up screw in my db2831-5088 combined with my non-eco friendly driving habits had me cleaning mine every 2500 miles roughly. But I know the new build would max me out at probably 1500 mile intervals- so mine will go away. If only I could get my hands on that donaldson blue... it would solve my issue.
Which btw-for everyone here that remembers THE FILTER TEST- that AC Delco filter that had the wazoo numbers- yeah that was donaldson making that filter for AC Delco and direst to GM under the AC Delco part number- incase you aren’t aware.
So those magical filters simply are not for sale anymore.
