Greetings, I have a 1994 2500 pickup, 4x4 with the 6.5 turbo and auto. It wants to over rev on a cold start to 2000 rpm's, then will idle down to 600 when it warms up. I read that it could be the temp sensor in a discussion. Will replace that. My bigger issue is that it pulls great and doesn't smoke on acceleration. Will pull like a demon to whatever speed you want, but when you let off the accelerator and just want to cruise, the engine rolls, or as some call it, fish-biting. It continuously surges down the road. If I decelerate it quits and when I accelerate it stop surging but if I try to maintain a steady speed, then it starts again. I replaced accelerator pedal, first year of fly-by-wire. Air intake temp sensor in plenum, fuel filter, although it only had 3000 miles on one I replaced. Also new PDM, which is mounted on right fender, in front of oval hole and replaced the sensor on the firewall, I think it's the MAP sensor. If anyone has had experience with, and fixed, either of these issues, I would be grateful for you assistance. The things I replaced were small dollar items and I hope to eliminate potential side issues. Next stop is some shop but I cringe at thinking about them just swapping expensive parts until it'd fixed. Thanks in advance.
