Hey guys. So not sure if I mentioned it, I finally got the dash tach to work. I was messing with the dakota digital unit for ages & finally said screw it. Hooked the tach in signal for the gauge directly to the cummins w terminal & it's working! Does anyone know if this will provide accurate tach readings or not? It says its idling at 800 but to me it sounds like its idling higher. However, I am not too familiar with cummins so I could be wrong.
Still trying to get the CPS from the cummins to read correctly. The EZ TCU unit I purchased is working great, but its providing full line pressure all the time as it doesn't know what the engine rpm is. Would work much better with that.
I wired the crank position sensor up with 5 volts in, ground, then the sensor return goes to the Dakota Digital unit. However, here is what's stumping me. 5 volts goes in, I'm reading 7 to 8 volts out. Is there a way to test the crank position sensor before purchasing a new one? Should I be feeding the sensor more than 5 volts?
Reading the schematics, it looked like the dodge pcm sends 5v in, then it reads off what is returned. My understanding is it would be lower than 5v?
Anyways, thoughts are appreciated!
