Hey guys. I just bought my first diesel a few months ago. It is a 1994 6.5 td. I had to replace the oil pan gasket and I noticed that the timing chain was pretty sloppy and loose. I don't feel like it has the power that it should so I figured this would be a good start by installing a double roller chain on it. I'm pretty good with a gas motors and I've changed plenty of chains on them. Is there anything special that I need to know or is it just as simple as lining the timing marks up? I know there is the ip gear too. Do I need any special tools etc? Thanks in advance!
