Joe putnal
Hi, I have a 95 k2500 6.5td and my vacuum pump locked up today and was wondering if I could delete it and if so how would I go about doing this? Thanks
Where the vacuum tube actually attaches to the actuator (close to the firewall on the driver's side), you have to plug the actuator or it will throw a code. I balled up some electrical tape and stuffed it in the end then wrapped the whole thing with electrical tape to hold it secure. Drove like that for three years with no problem.Wasn't there something simple for the electronics involved?
There may be other options, but you can use a electric vacuum pump from the ford's to run the heater controls.
Did these trucks already have hydro boost brakes? If not, can't really delete the pump. Lol
Sent from my SAMSUNG-SM-G890A using Tapatalk
I researched this yesterday: the only electric vacuum pump that has the inches of HG (posted) that is required and is built to function long term, costs more than a factory vacuum pump. The $50.00+shpg ford pump may be easier to install, but why bother with a cheaper 'iffy", or even the more expensive project??? The heater vacuum pumps are not made to perform up to what the stock or more expensive pumps are. They open and close the heater valve and blend door. I can do without the heat or the ability to choose where the heat comes out, but when I'm pulling 12k a hundred miles I don't want that plastic junk to give it up when I'm going up a hill - even if I have one of them in the toolbox for a spare. My luck it would be on the way home at 11 pm and raining when it stopped working, the SES light came on, and the power went away. I will gladly pay to avoid that experience.
Pepboys has a 25% off discount for online orders right now and they sell the same Dorman pumps that rockauto does with free shipping for store pickup. I'd rather pull the alternator and serp belt to replace the stock pump than rely on a little plastic $50 pump for such an important function. Just my opinion derived after much research. I'm not trying to offend anyone with a different opinion, I just don't see the point. But then , also, I do my own work for free, and would rather do one thing that is harder and have it last for years than do something cheaper twice, and then end up spending more to do what should have been done in the beginning.
Now, if you are comparing having a shop put the OE pump (at retail cost) on at $100+ an hour labor, it may be worth it to you to buy the good pump from Summit and put it on yourself. But, forget the plastic, electric, heater vac pump.
Last thing: if I was looking at a truck to buy and it had the $50 pump on it, I would immediately walk away, because, to me, it leaves the question of what other cheap shortcuts were taken when maintaining that truck.
Hope this helps.
No vaccum HVAC on GMT400. On non-ac trucks, it is accomplished with cable controls instead of vaccum.
