QinVB
I read recently that the lift pump for the 1993 GM diesels had higher pressures and was the LP that should be used. It supposedly has higher pressures - both static and after engine is started and makes life easier for the IP.
The LP on my '98 is sounding tired when I turn it on first thing. Takes a while to pump up. I'd like to put the Walbro on, but $'s a little tight right now, and the Rock has a brand name '93 for <$40.00!
Any opinion?
Any opinion?
