frostedapp
:mad2: Well... I just can't seem to get this truck running right. She idles fine and cruises good, but when I get up to about 50 or 55 mph and 2000 rpm the tach needle starts going nuts like someone is feathering the pedal, then the tach drops to nothing like I took my foot off the pedal, but didn't. if any of you remember I changed a a few parts, starting with new fuel lines from tank to lift pump, changed the whole sock assembly in the tank, changed the lift pump twice, changed the ops, changed the vac pump, and changed and relocated the pmd to the top of the manifold:. Is there some kind of solenoid ?
