dbrannon79
I'm getting there!
as long as the screws or bolts you used to lock up the old clutch won't shear off and allow the fan to freewheel again, it should last a few weeks or until you can get it all replaced.
as for the pump, order from @RockAutoLLC and get the Ac Delco pump for a 2000 6.5. if you go the electric fan clutch, order from the same place and look up the AC Delco one for a 2010 express van with a 6.6 d-max. use the plastic d-max fan blade for the same 2010 express van. iirc 2011 uses the same too. and then get the Hayden fan controller. there are three different styles you can use, each one is the same but with a different temp sensor. one with a stick in probe for the radiator, one with a 1/4" pipe thread and another with 1/8" pipe thread.
I got the one with the probe and strapped the probe to the back side of the t-stat crossover so I can use the port in the passenger head for a manual tamp gauge.
be sure to use the 5% discount code posted here in the vendor section from Rockauto.
