great white
War, the factory rating of 3600 is no doubt conservative, plus they won't breath or fuel above that anyway. I am really encouraged by the Heath Bonneville racer, because they used a scat crank, stock rods, and 6.2 pistons and ran it to 5000. I'll be happy if my engine still makes power at 4000, with a nice rpm factor of safety in case of a momentary over rev.
Is Ted's trucks the only place to get a rebuildable optimizer engine core? I don't want to pay $3k for a healthy engine, I would rather get one needing rebuilding.
http://www.dieselpowermag.com/featu..._diesel_race_engine/bosch_injection_pump.html
Don't forget: that engine had quite a few changes from stock, was twin turbo'd, and had the DS4 fuel tables populated out to 5 grand. It also only ran the salt and then went back on the trailer.
If you build it right, you can probably make a NA live up there, but getting the air in and out might be an issue.
You might be able to score a GEP 6.X off a gvt auction somewhere, or if you dig long and hard enough you may find a GEP somewhere else. Most of them are complete engines though and call for around the 2 grand mark.....
