scottm
Hi all, my first post. I apologize in advance for the length.. I come from the gas racing world, started drag racing a 327 Camaro in 1980, and since 2008 I have been racing a 1977 Chevy c10 class 8 desert race truck here in AZ. I have wanted to play with diesels for years now, plus I always like to do things a little different than the rest of the pack. Sooo my favorite bad idea right now is to build a max hp 6.5 na engine and put it in my desert truck just for the fun of it. The rules in class 8 don't allow forced induction, but besides that, I personally prefer to get the most out of an engine the old fashioned way - normally aspirated airflow and tuning.
I've been eavesdropping on the diesel forums for two years now, and I'm surprised that more people don't take the gas engine approach to diesels - porting and flow testing heads, trick intakes, cams, exhaust, etc, and a lot of dyno testing. I am most surprised at the lack of real headers for na diesels. The only reason a gas engine can make more than 1/2 hp per cubic inch is the exhaust, and the powerful suction or scavenging pulse that comes from a tuned header. Has anyone ever made a real header for the na 6.2/6.5 engine? (the military 'header' from the hummer is not a tuned header).
For a diesel making peak torque between 2000 -3000 rpm, I would say offhand the primary tubes should be about 1 1/2 inches diameter and at least 36 inches long. Combine headers with a strong short block, good flowing heads and a cam with a little overlap, and it should make more power than anyone would expect from a na diesel. I have access to a mandrel tubing bender, and I would love to fab up a set of stainless headers. BUT I need you guys to help me with the rest of the parts selection.
Torque comes from cylinder filling, and cylinder filling comes from air flow and exhaust tuning. Horsepower is torque x rpm, so the longer you can keep up the torque output (airflow), the more hp it will make. My engine build will start by extending the max safe rpm the engine can take, both so it can run strong into higher rpm, and so it can survive an over-rev from a broken driveline or a missed shift. What is the most rpm a stock 6.5 can physically survive? 3500? 4000? Whatever it is, I want to improve the bottom end and valve springs to extend the safe range as much as possible, within the reality of available parts.
From what I have read, the 92-93 6.5 blocks were the best for crack resistance. Is it possible to buy a AMG/GEP bare block?
What heads, factory or aftermarket, are best for crack resistance, airflow, and porting?
I will probably get the scat crank, and do a full race prep on a set of stock rods. Were any year rods known to be better than others?
Besides the Heath na cam, are any others available?
What would be the ideal compression ratio for this (relatively) high rpm engine? It must be easy starting in all weather.
What are my piston options? Lighter is better for higher rpm, and if they don't have it already, I will coat them with ceramic heat barrier and anti friction on the skirts.
What IP will be best for extended rpm and wide tuning adjustment?
I have access to a head flow bench, a chassis dyno and an engine dyno. The engine dyno is a Superflow water-brake type, and it does not work well at low rpm. The lowest it can absorb 400 ft-lbs is 3600 rpm. My plan right now is to find a cheap 6.5 td craigslist truck and take off the cab and bed. Then I can easily work on the engine and build headers, and just trailer it over to the chassis dyno shop for engine testing. No doubt people have known for 30+ years that this is all a bad idea, but even if it is, I will still have fun trying!
