greenmeanh1
First i have ever heard about a different gear set for our hubs. There is a 12k from 10k upgrade but as far as i know the top gear change is only to facilitate the larger updated input CV shaft. My diffs are Torsion 1 and are a 2:56 ratio. Wouldn't change a thing at this point. Truck runs very well. I have the original stock damper and its still in good shape but I keep an eye on it. With the high revs my biggest concern is the 242 T case. I change out the fluid a lot more often than suggested as a preventative measure. Same goes for the 4l80 transmission.
On a different note i thought i would add my cheezy build vid
