JMJNet
Recruit
Did you jump the truck? That can cause it too.
At this point, you probably want to get the tool.
Make sure it said 60G on it.
I found this http://www2.otctools.com/otctools.com/literature/201-1.pdf also looked at leroydiesel.com version and it seems to be better but is another 30$. Recommendations?
You have to start the engine,to pop them out with pressure. It works but it's dangerous,they shoot out like a bullet.
And there is a pic of the tools setup to pull out the #5 cylinder GP. I believe your supposed to turn the outside of the tool as to not twist the GP tip off but I had no way of turning it with the exhaust manifold on so I just held the outside with a wrench and turned the inside(did this on all 4 on the passenger side). Ended up working great and they all came out perfectly. I will get the Duraterms in tonight and will post a video of the result. Thanks for everyone's help.
