- Staff
- #21
P
PCM - Powertrain Control Module. The 'brain' of the vehicle. Can be reflashed for more economy/performance.
Info from chrisK1500
PMD - Pump mounted driver (aka FSD/fuel solenoid driver)- common failing part. Stock location is on the side of the injection pump. Failure results in stalling. This is not the only cause for stalling.
PMD - Stanadyne Technical Bulletin on the 'new' grey PMD.
Info from JMJNet
PMD Extension Cable - DIY: Solder or Crimp? - If you're planning a DIY- extension for relocating your PMD, then you need to read this very informative post before you start.
Info from Radio Man
Q
R
Radio Lights (Changing them) - Have the lights behind your radio buttons stopped working? Here is a pictorial look at how to change them out!
Info from great white
Recalls - Has there been a recall on your vehicle you should know about? Find out by querying this database.
RPO Codes - (Regular Production Options). Codes on your build sheet and located on the RPO label in your glove compartment that describe the factory options that your truck was originally equipped with. Try this handy RPO Lookup Tool and here http://www.thetruckstop.us/forum/showthread.php?36323-RPO-Codes&p=417507#post417507
Info from Mad Maxx
S
Serpentine Belt - Multi-V-Groove belt that drives the crankshaft-powered Utilities on the front of the engine... Alternator, Power-steering, Vacuum Pump, Water Pump and Fan. Routing diagram can be found here.
Info from 96 Oilburner
Service bulletins - Has there been a Service Bulletin about your vehicle you should know about? Find out by querying this database.
Starter Rebuild (gear-reduction) - Rebuild yours, DIY Step-by-step with pictures... See how to do it all here
Info from bison
T
Timing Stepper Motor - (ITS). Motor located on the passenger side of the IP that controls injection timing advance and retard.
Turbo / Wastegate System ... How does it work? See here
Info by knkreb
Turbo Master (TM) - Is a spring actuated wastegate that sets the boost pressure by adjusting the spring tension. This precision instrument from HeathDiesel controls the Turbo-boost pressure, eliminating the GM Vacuum Wastegate-control system. Often installed when vacuum pump fails or as an owner pulls off the vacuum pump. Can be bought from HeathDiesel for ~$100 or you can make your own version for ~$10-$20.
Info by Green Machine
DIY Turbo Master Step-by-step with pictures... how to build your own!
Info by mfgguru
DIY Turbo Master #2 Step-by-step with pictures... how to build your own!
Info by 625fireman
Turbo rebuild - (GM8) Rebuild yours, DIY Step-by-step with pictures... See how to do it all here!
Info by Bison
Info from JMJNet
Info from Radio Man
Q
R
Info from Mad Maxx
S
Info from bison
T
Info by knkreb
Info by mfgguru
Info by 625fireman
Info by Bison
