racer55
Have you checked to see if the fuel shut off solenoid is working?Often just holding it while a helper cycles the key to run should give you the feel and sound of a "click".
The FSO and PMD/IP fuel solenoid are both powered by the same fuse also so check your fuses(on OBDII it is called fuel sol fuse-not sure about OBD1).
