94DieselSub
@ Matuva – No to be contrary to others here, but if this is for a vehicle that has the 3/8” oil cooler lines and a non oil-squirter block I’d advise using a std-vol pump (esp if you use 15W-40). The HV pump was incorporated on the squirter blocks to compensate for the volume loss via the oil jets. On a non-HV application the HV pump will generate additional pressure that in all reality is just wasted energy (IE wasted fuel), and could cause the block located oil-cooler bypass valve to open much more often than with the std-Vol pump.
There is nothing to be gained by using a HV pump on a non-squirter block, other than lost MPG, additional wear & tear of the pump drive sys, and a small additional possibility of oil bypass valve failure do to constant activation. The Oil Pump drive sys includes the Camshaft, with the additional Tq load to the rear helical gear causing additional radial loading & wear of the rear Cam bearings. The 6.5L’s oiling priority is camshaft first, as such, camshaft bearing wear has a profound impact to oil pressure.
