6.2 NA Build - Changed plans... again.
Hey man you should just call Delta camshafts to get a cam for $140ish w/o core or $90ish with core. Paying $600 for cam and spring kit is not worth it IMO. Delta is a respected company and lots of members here have used them. I also have the part numbers for ARP studs for mains/heads/etc.
Yeah I appreciate it. I've had the block and heads over at the machinist for a while now. He called recently and said the heads are cracked, so I'm kinda just trying to figure out what I want to do and if I want to continue with this engine or not.
Well Clearwater cylinder heads is where I got my last set from and it was like $600 or so for them. I think there's cheaper ones out there possibly. Those Chinese knockoffs all come from the same place so it shouldn't matter as you'll have to take those heads to a machine shop to ensure the head work is correct and have the valve job recut. Doesn't sound like you should have to do that with new heads but my new ones are at the machine shop now getting new valve job, guides were too tight, etc. Great Chinese craftsmanship for you...
I have some good heads. Several sets to choose from. Would do some trading and have much more stuff. Maybe I could set you up with enough goodies to work out something. Just an idea.
