Jorge6.5
Is that a center mount turbo motor? Are they still using those cheesy nylon buttons for rocker arm retainers?
When was that? As of Jan 1 they had a price increase.
Leroy the mill looks pretty clean. How far will you dig into it? Check bearings?
Cant hurt. If its on a stand you can turn it upsidedown and maybe dislodge/clean more??The pics of yours look just like mine. The lower end is nice and clean just a little car on on the tops of the pistons.
But the water jackets are pretty gunky.
Do you think if I put one of those drain kings (one do those expandable water weenies ) in the water cross over with a hose and ran it for a while befor I hook up the rad it would wash it out?
Thats a good price, Im planing to have mine machined, but it depends on cost.Leroy I bought after market diamonds off ebay for I think $80. They are not non farious(spell?) and they stuck up just a hair. I have read of some people milling the pocket of the heads but my machine shop installed them and milled the cups flush with the head. Good or bad I don't know.
Leroy, I sent total seal the 2nd ring in the sets that came with the pistons from Kennedy...
Jsarge said:
Alright guys, after hunting down some information, some measuring, and sitting on the phone with ARP.. i have figured a few things out.
One of those things is that i've decided to leave all of the original main studs in place, except for the outer bolts on the center three mains (the failing points).
I've run into a questionable issue when it comes to those studs. The outer bolt's measure out to be 2 7/8" or 2.875 from the tip to the bottom of the head. Obviously, going to a stud you are going to want a bit more over all length than that for the nut. Here are the two studs that ARP had to offer:
[AU3.420-2LB] $15.84 ea
~ARP2000 material (220KSI) w/ black oxide finish
~3.420” overall length
~1.000” of M12x1.75
~.443 reduced diameter shank
~1.000” of M12x1.25
and
[AU3.965-1LB] $6.79 ea
~8740 material (190KSI) w/ black oxide finish
~3.965” overall length
~1.200” of M12x1.75
~.471” full diameter shank
~1.125” of M12x1.25
As far as the first option goes, it measures out to be perfect. After knocking off the thickness of an ARP washer and nut, it will leave about .165 of stud out of the nut once pulled down. However, i am questioning the fact, that this particular stud has a reduced shank size of .443. Would this cause stress on the main cap or anything else because the shank of the stud is .028 smaller? I figured it is doubtful but i want to ask all questions.
As far as the second stud they had to offer goes, it would actually be useless for an OEM type application because of the length of the threads and the overall length itself. Do the math, the shank of the stud will be slightly sicking out of the main cap .. being useless. However, this would be a perfect stud for someone making an outer girdle ~3/4" thick.
As far as the inner stud's go, i have a direct part number that will work out well: (this stud is probably also available in the ARP2000 material if you ask)
[AU4.795-1L] $10.87 ea
~4.795” overall length
~1.000” of M12x1.75
~1.000” of M12x1.25
Sorry... I missed Diesel Cash had posted the same info on another thread. Went looking and no luck on the 10mm outer studs. Summit does carry/ sell ARP 10mm studs but I believe they are too long unless you are running a girdle. Do not were or how Heath gets them but they list ARP studs as a set for both 12mm and 10mm outer bolts on caps caps with no girdle. Looked on the ARP and that was pretty useless... I guess the quest goes on. I will keep my eyes open.
For the rings, I went straight to "Perfect Circle", cost is 10.00$ each ring, you send them your ring, in our case the 2nd ring, and they machine the grove in the ring AND supply the ring that goes in that grove making it true gapless... 1 day turn around....
Thats the brand I bought, but paid way more than $10 a hole, you sure about that? They will be shooting themselves in the foot. What brand rings did you send them?
Sweet, I'll have to do that.
Makes sense, your not buying a set and most probably don't know that little trick.
If your selling your precups, I'd be interested in them.
This begs the question, What are you guys using for rings (brand/part #)?
