vegtech
WVO Enthusiast
so the Yukon broke the block and I bought a low miles hummer take out from Ted's, per advice from you peaple. Teds is verry nice to deal with by the way. I plan to remove the heads to use my arp studs from my 929 block. while apart i will install .010 thicker gaskets. I'm sure it wont drop the CR to 18:1 but at least some. I also plan to install the main studs and girdle. this should make it pretty bullet proof for what i put it through.I also plan to rebuild my injectors with the 40hp nozzels. I am wondering if anyone has played around with the pre cups, machining them out larger. I know people desire the larger cups but has anyone taken what they have and made it larger?
