Bullseye240
Update; tranmisson arived at the shop yesterday.):h I will be installing it along with a few upgrades this weekend. I have three days to work with so I should have enough time to get it done. I plan on installing the B&M cooler along with the oil cooler under the truck behind the trans with a 10 inch electric fan controlled by a temp switch. I purchased one of those pans with the cooling tubes in it to see how well it works as well as a tube/cooler flushing kit for the factory lines. BTW any one know for sure which line is the output from the transmission? As I would like to "back flush" the lines. I also plan on undercoating the truck with a DIY roll on bed liner kit for rustproofing and sound deadening while the trans is out and access is easy. Also plan on adding a spin on filter for the trans that can be regulary changed easily. Reason for moving the oil and tranny cooler under the truck is to allow cooler air to get to the rad for better cooling. Man I miss driving my Blazer:sad:, but it will be back on the road again soon:thumbsup:. Also have nothing but good things to say so far about Everdrive.com and their service. they sent me like three different e-mails about the transmission as well as a couple of follow up phone calls.:thumbsup:
