Arthur hodge
Hi how are youll doing Look I have a 97 Chevy 3500 with the 6.5 turbo with the 4l80e transmission I had the transmission start giving me problems it would not shift I only had 2 and reverse I changed the speed sensors temp switch checked the switch so I pulled all the plugs on the trans and cleaned with electrical cleaner and put all the plugs back in place started shifting and then it started it agen I repeated my steps as before but that is not doing it can someone give me something more to look at and if you can email me.@ [email protected]
