GenBiltstein
- Messages
- 46
- Reaction score
- 52
Our TPS is actually the accelerator pedal with 3 sensors, and it only needs two to be working correctly. And the computer knows if those are out of whack usually if they arent agreeing. You cannot adjust them.
Agreed.
Agreed again.The tranny main line pressure is set from that pedal position (%TPS), and speed (MPH).
This pressure adjustment we are talking about is sometimes referred as governed pressure because of vehicle speed
as the vehicle speed is sensed.(MPH)
The Throttle position sensor sends TP signal to the computer. The pressure adjusted at the PCS solenoid is not completely performed from the TPS.
PCS amperage should always be compared to line pressure from the pressure port as part of troubleshooting.
TPS or APP position should always be checked against PCS amperage.
Agreed.The scanner can show what the desired is and you can compare to gauge, and scanner can even set it higher to make sure it will actually change with desired settings.
Good information.
