Husker6.5
Ok, '98 K2500 Suburban LT, 198K on odometer, tranny never rebuilt as far as I know, last fluid flush unknown. Fluid condition shows signs of overheating in past, no signs of "floaters" on dipstick, but doesn't mean there aren't any in the fluid. Hesitant to have a full system flush done at this time because I've seen more than one weak transmission decide that the time to fail is right after you flush all the "friction chunks" out of it and put fresh fluid in.
Ever since I bought it a year ago it has this totally annoying habit that once it's in OD and the TCC locks, all is fine while I'm driving up any sort of grade or the engine has a load on it and it's "pulling". When I come to a downgrade the TCC will unlock and RPM will jump up 150-200, then it will relock and the RPM will drop, then it will unlock and RPM will jump up, then it will relock and RPM will drop. It will cycle like this about every second or two, and is like riding on a bucking bronco (not Ford-kind!) all the way to the bottom of the grade until the cruise accelerates on the level or a slight upgrade and it locks back up, or I give it a little throttle on the downgrade to keep the motor "pulling", but there are times I hit the bottom of the hill at 90+MPH doing that! It does this unlock-relock cycle whether it's on cruise or if I'm using the throttle and my foot, however if I'm on the pedal, it's worse as the bucking makes my foot bounce up and down and I wind up getting swings of 300-400 RPM as it unlocks and locks, whee! (NOT!) This is definitely not coast clutch or override clutch disengagement, it's the TCC.
Logic says that as the load INCREASES on the torque converter and tranny going uphill, that's when the TCC would unlock to give the engine some more RPM (like it does on my '94 C2500 6.5 when I have a full load in the bed and am grossing 10K vehicle weight, but my '94 doesn't do the unlock-lock thing going downhill regardless of the vehicle load), NOT when the engine load lightens going downhill.
I took it to a very good and reputable local transmission shop that my mechanic uses. The owner (over 30 years experience) hooked up a SnapOn solus scanner to the ECM and did a scan for any codes in it or the TCM, there were none. With it hooked up, we took the 'Burb out for an hour test drive on the Interstate and local roads to replicate the unlock-lock (which it did). The scanner showed the solenoids operating for the upshifts and downshifts, line pressures were in normal ranges, everything seemed to check out ok, other than the damn unlock-lock thing on the downgrades. He concluded that it could very well be that the ECM was "telling" the TCC to cycle off and on for some reason, and that a reflash of the ECM might help.
I had my mechanic use his GM Tech 2 and go on-line to download the newest GM program for my ECM. The Tech 2 showed that the last update to the ECM was in mid '99, nothing since, and that there were two upgrades from GM since then, so the newest was downloaded and my ECM reflashed. Well, it didn't solve the unlock-lock problem of the TCC, but I did gain smoother idling, better throttle response and about 2.5-3 mpg better on the highway from it.
Now for the $64,000 question: Is it possible that there is a piece of debris in the TCC lockup solenoid circuit that causes the solenoid to release when the engine "backs off" that a good flush (tapping into the trans cooler line and flushing with the engine running while on the machine)would cure, or perhaps it's a case of the solenoid plunger bore being worn and it needs to be sleeved that's causing the unlock-lock sequence? While the shifts on this transmission are softer than those on my freshly (30K ago) rebuilt '94's 4L80E, and there is a slight hesitation in the 1-2 upshift occasionally (which hopefully would be cured with a flush and fresh fluid), my impression from the test ride with the transmission tech was that the overall health of the transmission is ok based off of line pressures and shifting via the scanner, and should get me by just fine for quite a while if we can just solve the TCC unlock-lock gremlin.
Any of you out there have a similar experience with your 4L80E, or have the technical experience to know what is causing this? Any help will be highly appreciated as this 'Burb is used primarily for long distance trips (like from Lincoln to Chicago, or to D.C., or to L.A/S.F. and back, or to Ann Arbor for a football game, etc.) and the downhill lurching gets old in a HURRY for my kids or friends after four or five hours of it.
Thanks.
Thanks.
