midniteplowboyy
Recruit
Any of you guys out there with the '92-'93 mech injected 6.5TD and 4L80E: does the TCC unlock when you ease up on the go pedal, at some speed above 45mph?
Watch the tachometer, where available:
- if engine rpm remains steady, dropping slowly as vehicle slows, you have lockup
- if engine rpm drops rapidly to some lower rpm, then dropping slowly as vehicle slows, you have unlock, just like the EFI versions
Yes they unlock when you let most of the way up on the go pedal, I have an LED on my TCC solenoid wire so I can see when the TCM or me has it locked.
I thought all the solenoids remained the same in the 4L80 except the pressure control solenoid that they change in 94 combined with the different valve body.
Let me ohm some of the new GM 4L80's we put in HMMWV's, they use the same TCM as the mechanical 94up van did, with the same 94up trans/valvebody. I'll also see what the Tech-II shows on modulation percent/frequency of the TCC solenoid.
