Will L.
Ok. If the trans light is on when it is not connected and the tachometer does not work with it disconnected...
Then connected the trans warning light goes out and tachometer works- that is probably not the problem. I can’t understand how the tachometer would work if it didn’t have the reluctor wheel in place. I am assuming the tach is showing proper rpm (at least apparently)
@THEFERMANATOR becomes the go to guy again.
