Roberttx13
Thanks everyone this is steps forward I'll set off tomorrow to see if I can get the obd to respond to the test I'll isolate all the curcits to find the problem. So if the tcm were to fail could it possibly cause the ses light to illuminate because weeks ago when it ran good there were no lights on at all. And is there a way to test the tcm once I have confirmed all bad wires and grounds are corrected in the system? Great tip about putting load on the circuit it makes good sense but never occurred to me!! First and foremost Ill get the obd to respond to the test!You should say don't always turn the light on. Some DO turn the light on for trans codes.
No, you will not have battery power to your aldl plug. Do not use a truck manual, use a van manual for 95. There are differences between a truck and van. Sounds to me like a power or ground issue to the controller(ECM, TCM, engine or trans controller, whatever you want to call it). GM many times used basically an engine controller for the 4l80e as it needed a good controller to run it with multiple PWM outputs. Failed controllers is not uncommon on obd1 generation controllers. They werenot the best built, and low voltage can kill them in a hurry. I wouldn't worry about anything else until you can get your controller to respond to the code check test. Verify you have power AND ground to all neccesary wires at the tcm. Use a test light with a decent size bulb to simulate a load. I've seen them showvoltage with a dvom, but go to 0 when connected dueto poor connections, so you need to verify the circuit can hold somecurrent load. Next up is unplug the tps, engine speed sensor, trans, and speed sensors. Any shorts to ground can short the controller and prevent it from working. The 1st goal you have to do is to communicate with the controller. If a shorted sensor or input is found shorti,g it, then you have to fix it. If you completely isolate all circuits to the tcm and still can't communicate with it, then theres a good chance you popped the tcm trying to start it with dead battery's. And you need to find out what is killing your batteries to prevent this from happening again.
