hereismylife
formerly j k auto
I am wondering why it will not shift at wot. If I leave off a tad it will shift perfect through all the gears.
I was searching this for awhile and came up with some questions.
I am still wondering what does the tps actually control? Why does it have to be at 1-1.2 at idle and 2.2-2.9 at wot? ( I do have a standalone ats valve body and can check what the low & high settings are).
Does the tv cable actually change the upshift? I did find out it is also a kickdown cable if I am right.
I am tring to figure out if my problem is in the standalone or the adjustments on my linkage.
thanks
thanks
