Good technique! I bet that helps with fuel mileage also. :thumbsup:When I approach a stop sign or red light I will coast from afar and most of the times I will be pushing the go pedal and I haven't lost any ground. I am right back in the thick of traffic
I treat mine really easy, I thought for sure I needed a new hub, but they couldn't find anything wrong with it. Now I am working on 309k miles.....Original front end... as in pitman, idler, ball joints? That's awesome... I've been through piles of those parts on mine with less than 250k!
Any way to get the same brake pad material for the older model trucks like my '99?
You need to get rid of the obsolete rear drums 1st. Then look at the small rotors and pads your 1999 has vs. the newer 16-17" rims and larger rotors. The undersized system will just not last like the newer ones. Best thing you can do is manually adjust the drums up every oil change.
It is just a brake system redesign done around 2000, 1999 on 1/2 ton pickups. Sadly GM went to rear drums again on 1/2 ton pickups in 2005.
