SmithvilleD
Active Member
I think my GM shop manual mentions some type of driveshaft mounted brake? Possibly an option on the HD chassis cab models?
Check out the TSM link that 83GMC gave they have driveshaft brakes available.
I'm not crazy about a drive shaft brake, either. Better than nothing, I guess.
Talk about delayed replies, Matt it took you from April to now to think of that?Or slow nite and your re-reading old posts :thumbsup:
Please keep us posted when you've swapped in the OEM axle with rear discs setup.
The aftermarket brackets that utilize the earlier GM 3/4T rotors/calipers look reasonable except no parking brake. Another option out there uses older Cadillac El Dorado calipers that included an OEM parking brake setup. I've heard rather mixed reviews on how that parking brake works.
Swapping to rear discs interests me but I'll want a reliable/trustable parking brake setup (my truck's a 5 spd). One would hope GM engineered an effective parking brake setup for rear disc brakes by 2004.
Regardless of my wish that the OEM 14 bolt/10.5 rear disc brake setups from 3/4T gassers includes an effective parking brake; I'd much rather hear from an owner using such a setup.
I have the rear disk conversion using the Cadillac Eldorado rear brakes and calipers. The rear parking brake does leave a little to be desired. It takes a lot of pressure to get the brakes to hold on a hill. The truck has a tendency to roll backwards, flat surface is ok but I wouldn't trust it to hold on its own on a hill rolling backwards.
That being said I have love the stopping power of the brakes they are 100 percent better with a load behind them
Okay, now there's some credible data from a guy that tows a real load. The question remains though, what can I hang my hat on when I'm parking on a hill with 20,000# of truck, trailer, and horses? Wheel chocks?
(I'm also thinking of what to train the wife to do if she's parked on the side of the road with three horses in the back. This alone could sway me back towards the 13" rear drums.)
Is the parking brake on the later model 4-wheel-disk trucks capable of holding this much?
Mike
Mike
Hey Slim thanks for the input, what I was looking for in the other thread that I started.
My one concern though is that of the proportioning valve. My worry being that the rears start locking up before the fronts. Now my conversation with TSM they said that the ABS takes care of all that. The thing is it seems counterintuitive to me for more braking power to have a bias where the rears are now locking up before the fronts and the ABS is coming on to relieve this situation. My question is how does the bias feel after the conversion is the ABS activating more?
Good discussion on the parking brake as well that is important to me also. I am seriously pondering in my case changing out from my SF to a FF axle with the hope that the extra 1" of shoe width will make a difference to braking in my case.
Cheers
Nobby
