- Staff
- #61
WTF
I hate reccomending him because of an issue with somebody I sent to him, but Tony at Ridgerunner has posted about this issue and said he has the cax files to correct it. I would check with Danville 1st. He doesn't list it anymore, but his tuning is top notch, I just don't know how much he does with lml's.
Some have gotten a 10x1.5mm adapter and put it in the bleed screw hole in the top of the stock fuel filter housing. For a cp3 you only want 8-10 psi of supply pressure, anymore and you will have rail pressure issues.
You could tee in or remove the test port and install it there with a hose barb fitting.Isnt there a fuel pressure port at the front of these motors? Kennedy had a snap in fuel pressure gauge at one time.
Would have to double check, but I believe it was 5/16" hose going to the test port.What size of hose?
