2007 ram 3500 with 5.9 Cummins a/c won't work.
edlib3
A/c compressor froze up on my 07 ram 3500 5.9 Cummins. So I replaced it along with everything under hood and dash. Only get hot air now.
Did you replace the HVAC blend doors?
Is the fan clutch less than 5 years old and a MOPAR unit? (Not iffy aftermarket or parts store trouble.)
Is the compressor turning?
If so are the A/C lines at the firewall both getting cold?
If you don't have voltage to the compressor coil, not turning, not these have a TIPM that fail like a fuse esp when a coil shorts out when burning up. It may be able to be reset by a dealer.
