trouttrooper
Big Blocks ROCK!!!
So I know I've been pretty much absent here for a long time. Life went to shit about 4 years ago, but I'm back on my feet again after finally clearing out the last debt my ex left me. May even have to give ol Dave Ramsey a call one of these days. LOL
So the Beast, 2005 Silverado 3500 CCLB, has a parking brake issue I'm struggling in finding the correct help. It doesn't work....obviously or I wouldn't be here. It is NOT an issue at the rear tires. Both sides are adjusted correctly and I can move the cable at both tires. The cable running back is extremely loose, in that I can grab it and almost do a half hitch around my arm. The pedal itself has absolutely no tension on it, if I hit a pothole it will actually depress itself enough to turn on the brake warning light in the dash. I have to literally lift the pedal up while holding the release lever to get it to go all the way up. It only starts moving the cable when it's already halfway to the floor.
I've read where there is suppose to be an auto adjustment in the pedal assembly itself, but I can not find a good diagram of how it works or how to fix it. I'm guessing mine has seized up from lack of use. I doubt the cables have stretched that much because I've hardly ever used the parking brake. Anyone have a good schematic of the pedal assembly or advice on this?
Thanks.
Thanks.
