Detroit Dan
the "centric would only be an issue if they were spacers that bolt directly behind the wheels. These spacers bolt to the hub using the same "centric" system your wheels did. Then the wheel bolts to the spacer, again using the same "centric" as before. So whether it's hub or lug centric, you're doing it the same. I've got essentialy the same thing in between my duals to move them apart.
