Matt Bachand
Depends on the 6.5
Anyone shopvac out the inside of a fuel tank before? I assume there will be no problem....................
:firedevil:
:firedevil:
All this talk about grounds reminds me of GMCTD... anyone hear from the ol' bugger lately?
Spent close to 2 hrs on phone with him last nite, he's had a full plate and has not been on the web much lately, at all actually, he did not say when he might be back with us regularly again, it's rough being retired,![]()
Well, can't rule out PMD until you do a THOROUGH ground cleaning.
Seems good so far. The voltage being back up above 14 at all times is just an added bonus. In fact, with all my 30+ marker bulbs, and fan on high, it sits square at 14.
I'm going to take the older cable that was too short, and possibly put that straight from D.S. neg to frame. (same bolt that holds brake line on is easy to access and re-use.
Adding the addition grounds from D.S. Neg to frame, and P.S Engine (where P.S. Battery neg bolts to) to frame couldn't possibly cause my alternator failure?
Cooincedence? (sp?)
