Big T
14K views · 27K reactions | Timing Chain Slack is a Power Killer | Dave's Auto Center
That's not that much, you should see how loose the Cloyes single roller performance chain sets are on these engines, not to mention how noisy they are. The thing with this style chain is they stretch a certain amount and that tends to be it. So long as you don't run thick oil in them they're pretty easy on the chains, but if you run thick oil, they'll stretch the chains right out from driving the oil pump.![]()
Timing Chain Slack is a Power Killerwww.facebook.com
They're real sloppy after 400,000 miles or so.That's not that much, you should see how loose the Cloyes single roller performance chain sets are on these engines, not to mention how noisy they are. The thing with this style chain is they stretch a certain amount and that tends to be it. So long as you don't run thick oil in them they're pretty easy on the chains, but if you run thick oil, they'll stretch the chains right out from driving the oil pump.
