Not sure if that is normal blow by or not but I would imagine not. Engine has about 160k on it, I did basic maintenance to it drove it for 6 months on weekends, then it sat for 7 years without being started and a couple weeks ago it cranked up fine. Then the injection pump ate shit from sitting for so long. Did the FTB mod with walbro lift pump, has a new injection pump, SS Diesel economy injectors that are 7 years old but only have 2,000 miles on them, glow plugs are the same story old but no miles. Engine ran fine when it was shut down 7 years ago. Also has a new water pump, crank sensor, boost solenoid, MAP sensor, #9 resistor on an old but low miles PMD remote mounted of course.
It runs rough at idle you can feel the shake in the whole truck though it doesn't look that bad in the video or sound that bad really. I have a tech2 so I did a cylinder balance test and it doesnt seem isolated to one specific cylinder as they all drop the RPM evenly. Entire fuel system is new, the switching valve and both tanks and pickups and filter and housing cleaned, fuel level sensors etc... All new. I tried the time set function on the tech2 and it is sitting around 9.4 degrees at idle, if you hit the button it drops towards zero, right around 4-5 degrees the noise and the shake disappears runs real smooth. Any ideas?
