ak diesel driver
6.5 driver
Probably better said but I'd run it for a bit and maybe wiggle the wires to check it for intermittent/poor connections
Thank you much. That maDe it clear to me!!Ok I would like to jump in and reword what AK is saying -no offense, I think it is just getting complicated.
To do the test. It will be hard to start, may take 15- 20 start. Once it starts and revs up, turn it off- no test drive needed. Any misfire afterwards is irrelevant.
1. Tell them unplug the cps and try to start it.
A. If it doesn’t start, the optic sensor is bad.
B. If it starts the optic sensor is working.
2. Plug it back in. Unplug the optic sensor.
A. If it doesn’t start, the cps is bad.
B. If it starts the cps is good.
Sounds like the engine is cutting out and this can cause a downshift. At the minimum the TCC will unlock and then lock back up when the engine is running ok again. Fishbite is the term you are looking for for a single miss that you feel.
It's possible you have air in the fuel system, gelling fuel... What's the lift pump PSI at the water drain now, how old is the fuel filter, and is the fuel heater working? Water at fuel drain? Fuel smell like gasoline?
